Can't get the darn tire off
12K views 29 replies 13 participants last post by  deidramiller763
2013 corolla with dead flat left front tire. It was moved around a lot to get at. The tire won't budge tried hammering at wheel from behind. Any ideas on what to try and thanks in advance.
Are you trying to dismount the tire while it's on the car? Or are you trying to remove the wheel/tire, so that you can put the spare on?
If it's the latter, the wheel is seized to the brake disc. Since you can't get it off from beating on it from behind, call a tow truck, hopefully you're not on the emergency jack. Hopefully you have AAA or roadside assistance on your car insurance, then they can try to remove the seized wheel from the brake rotor, in a safer manner.
#21 ·
Had same problem once on front wheel.
A. Loosen lug nuts a few turns.
B. Startt car.
C. While stopped, turn steering wheel full lock left right left right until the torque pops the wheel/tire combo loose from the hub.
I've wire brushed the hubs, then added anti-sieze to prevent it happening next time.
Grease not as good as it heats up from heavy braking or hot summer day, drips off.
#22 ·
shaking the car with lug nuts off could bend a stud... last time mine were stuck I used brake fluid that I poured on the hub, and sat down in front of the wheel with back support and kick it very hard with both feets about 10 times, if it doesnt work, more fluid/penetrating oil and wait more. then kick it some more
