Differential fill and drain plug location information is needed.
2.9K views 5 replies 3 participants last post by  rickhl
Need, DIY differential gear oil change procedure / instructions. The differential case is "covered" with hex bolt heads of the same type. I can't find any that have a visible sign that they may be anything but fasteners as opposed to fill of drain port plugs. Have spent hours searching the internet for a clue. It's as if a 2016 Camry doesn't have a differential at all. Could it be that the only way to drain and refill the differential it is to take it apart?
Well Dang this has got to be the fastest maintenance I've ever done, 3 cars in 1 reading, LOL since ATF is shared between transmission and differential then I don't need to do any diff fluid change, perfect, since my ATF's are all new
