I now have no hi-beams or low-beams on the passenger side of the car. I've replaced all fuses with brand new ones, and cleaned out the connectors with cleaner and got all of the dirt and grease off and inside the connectors so it's clean. I also checked my relay and ground on the actual harness that the headlights are connected to and they seem to be fine. Relay and switch works because it's in good shape and the blue headlight indicator appears on the dash. Everything works except the passenger side hi-beam and low-beam but all of the lights work perfectly fine.
Also, I've tried many things and still can't get the hi-beam and low-beam to turn on and I've tried multiple bulbs, so the issue isn't a bulb. The ground seems pretty intact and not rusted so I don't think that is the issue here. I'm pretty frustrated on this entire thing and have been trying to figure it out all day. I just wanted to make a thread to see if anyone else has advice or has had similar issues the same as me. The last time I remember I hit a bump and the low-beam flickered off, and then hi-beam went off after a while, not sure if that has to do with anything.
Anyways, I hopefully someone can help me or give me advise otherwise I'm probably going to drop my car off to someone who can figure out the problem and that has experience with the wiring because I suck at wires. I don't have a volt reader so I can't really test wires and see if they even have power or not.
