Hello TN folks,
89 Camry LE Wagon, 135,000. My problem is that I hear a cracking or creaking noise from the lower front wheel area. I have replaced everything control arms, rotors, struts, inner and outer tie rods. The ball joints were replaced but sometime ago; and they are cheap parts for offline. My question. is it hard to replace ball joints. I have a new one around the house. I know that I may need the fork or device to separate the ball joint from control arm, but will I need anything else to do the job. Additionally, when doing a code check what to areas to you run the wires or paper clip to get error codes....
Thanks again,
EastoftheRiver - Capitol Hill
Thanks again,
