^+1 above
Let me clarify: Strut bars and Anti-sway bars will do NOTHING to prevent nose dive during braking! Zip!
The term "anti-sway" is for torsional differences imposed upon the body from the wheels being pushed into the ground or lifted from the ground by the affects of body roll side to side. No body roll, no help. You could throw it away and it would brake the same under most circumstances.
As for the brace, if you plan to autocross, go for it. Otherwise its just bling and added weight. << :disappoin I know I'll take some heat for that. . .
If someone was to get serious about making a camry handle, the first step after lowing the CG would be to ditch the rubber biscuits insulating the sub-frames from the body and replace the rubber bushings in the lower A-arms with something more solid. Teflon, urethan, brass, or actual bearings, ect . . . Same for the rack and anti-sway bars. Until then I doubt there is any gain what so ever no matter how much the strut bar $bling$ costs!
Has anyone seen urethane sub-frame biscuits? Do they make them for a cami? Road noise would go through the ceiling but the 13" can outback prolly makes it irrelivent!
