Ok let's try and be logical.
@Vangm25 , nice basic to OCD write-up. I'd edit to add the warning "Lower vehicle then fill.... If using ramps don't do that. Put some oil first before driving it off the ramps"
Also what the f*ck do you need the window down to do an oil change?
Now on to debunking pre-filling filter...
The few "impurities" are pretty insignificant since if you have a V6 you'll be dumping 6 quarts of "impurities" straight through the top of the engine over the cams and down the oil passages and end up in the oil pan.
Watch 1000 YoyoTube videos and you'll get 900 stupid "you have to do this or it will kill your engine" videos.
1 - Canister screw on filter - use NEW oil and lubricate the seal. screw that. You're under the car. The drained oil is under the car. The new oil goes in from the top, Take finger dip it in the drain pan and smear that seal. It's going against the engine block and has a single purpose so the rubber doesn't stick like glue to the engine. Noting else. Just try it without oil and tell us how much fun you have getting it off next oil change
2 - Stupid messy cartridge filter with metal holder. Notice the difference between it and the plastic one. Plastic has no drain plug. There's one O ring seal in the box. Metal one there's 2 O rings. Guess where the Toyota stealership oil change monkey puts it.... In the garbage! (unless he's a collector) They don't waste time draining it. They take the whole thing off and drain it.
Me I'm keeping that little guy since I barely drive and oil still ages and needs to be changed. I buy FRAM Ultra Synthetic Oil Filters. And guess what. Now that my Avalon has good oil and a great filter and new O-Rings. Come next year the oil filter ain't going anywhere till the next oil change. Unscrew the plug and drain the filter. Use next filter's O-Ring and drain pipe and away me go to the drain plug. Hey? Wait! Where's the drain plug?
There ain't none. EZ-OIL drain valve, adaptor and drain hose. No Mess no where's my washer and no looking for the drain bolt that blasted out of my hands.
That's my KISS procedure!
No need to repeat the mess from the first one. And if it wasn't a 2013 Avalon Limited I'd test pushing that oil filter to 20K miles without replacing it. But I'm going to play it a bit safer. And at 99% filtration for 11.49 Canadian it'll keep my oil and engine cleaner than cheap Toyota toilet paper filters every oil change.
Now he may be long winded and a Toyota only parts and cleaners fan but if there's one guy that knows Yotas it's the Car Care Nut Guy. Watch his oil change explanation videos.
What next? Use a paint shop filter to fill your engine oil?
