Power Steering Fluid Verification
11K views 13 replies 10 participants last post by  Kingdom934
Hi all,
SFCamry told me I could but can Toyota W/S be used as power steering fluid? I plan doing my ATF Filter in about six months (roughly 5000 miles) from now and since Toyota W/S can be used I might as well do a power steering flush too. Otherwise, what have you used for power steering fluid?
(I plan on sticking with Toyota W/S instead of the popular Valvoline MaxLife)
We'll see if other's chime in, but I would just use Valvoline Maxlife ATF. Cheaper. PS fluid is transmission fluid, usually without a dye. Maxlife in the tranny and in the PS - easy peasy, and no need to buy and store two different fluids. Been in my Camry for well over 100k miles. But if you do want to stick with W/S, then go ahead. I'd trust that over some AutoZone stuff any day.
Let's see who wants to argue that you need a special PS fluid from Toyota.
Maxlife in PS too. I did the bleed out thing (jack up the car, redirect the return line, lock to lock the steering) when I got the car a few years ago. I pump out the reservoir and add new every 5000k when I change the oil and filter. I do add a bit of Lucas Synthetic oil additive too.
But when the cold start temp is below 50 F or so, the pump still briefly moans like something very, very unsophisticated, reminding me that Toyota design ain't what it used to be. Oh, and the factory PS supply line and clamp is already seeping.
c'mon people, what's happening to this forum? we're still on the first page of what should be a multipage discussion regarding the virtues of using ONLY fluids branded TOYOTA on these ~20 year old cars as anything else can and most certainly will cause premature catastrophic failure - as we all know.
I only buy fluids that are personally filled by Mr. Toyoda himself and that come directly from Japan and are then sold directly and exclusively to Toyota dealership's parts departments.
If you buy some other fluid that says it's compatible, even if the owner's manual says they meet the specifications, how can we be sure they are actually good for our cars?
(bazinga)
tony
#8 · (Edited)
As AurionX2 points out, Toyota recommends ATF Dexron Type II or III for PS fluid. No reason not to follow this recommendation as Dexron III is widely available and Toyota is not trying to make money here. You can get a gallon for $14 at walmart for Valvoline Dex/Merc, in the blue bottle - It's Dexron III. Or save a buck and get the cheaper SuperTech brand. I flushed all my Toyota's, including the Lexus, with Valvoline. A gallon easily covers two vehicles.
See page 310 of your owner's manual on this electronic version from Toyota's website:
https://www.toyota.com/t3Portal/document/om-s/OM33751U/pdf/OM33751U.pdf
https://www.toyota.com/owners/home?...cleList=false&remRecentVehicle=false&csrfToken=15401909974689049374822811911861
#14 ·
I've used Maxlife in all my Toyota and my IS250. It's worked fine so far, but again YMMV. I sometimes use Dex III in cars that do call for it if I'm being cheap or if that was what was being used.
I only been using Maxlife for anything calling for T-IV / WS....of course.
