I opened my driver door and noticed that the lower inside of the door was wet. Furthermore, I could see water between metal and the plastic, which I circled. Should I be concerned that this will lead to paint issues?
Water splashes up from under the opening of the door. In the winter, slush accumulates precisely in that area due to its inherent design. All to say, this is normal.I opened my driver door and noticed that the lower inside of the door was wet. Furthermore, I could see water between metal and the plastic, which I circled. Should I be concerned that this will lead to paint issues? View attachment 327821
Just bought a 2021 Highlander Limited. Mine is missing this whole rubber gasket, all I see is paint. Can one you guys tell me what this part is called and where I can find replacement for drivers door?I opened my driver door and noticed that the lower inside of the door was wet. Furthermore, I could see water between metal and the plastic, which I circled. Should I be concerned that this will lead to paint issues? View attachment 327821
