I just bought a 2015 camry xle 2.5l vin starting with 4t4. It has 100k miles and looks to be all original parts.
I have some rear sway in the rear of the car. I jacked up the car to inspect and from what I can see and feel with a pry bar, I have worn trailing arm bushings and some worn out sway bar end links. I can't seem to find the bushing for the trailing arm. Does anyone know if I can just replace the bushing or do I have to buy an entirely new trailing arm? I'd perfer to stick to oem if it's not insanely expensive otherwise, aftermarket is fine as long as it's not some cheap $5 part off ebay.
The part number for the whole arm is 487A006011 and is from parts.toyota website. If you look at the picture, it's the bushing on the left. Thanks
