So I just received my parts yesterday. Today I go and I install these lights. I ran into 3 issues but there is one issue I need to still get fixed.
Issue 1 : turn signal was not lighting up. Messed around with it and I got it to work. You can't turn the caps on these too far bc they use metal contacts and if you go too far the metal contacts won't sit right. DONT OVERTIGHTEN !!!
problem 2 : I dropped a turn signal bulb and now its a dud. Thats my fault lol ill get a new one but these bulbs are a bitch to get to without taking everything apart again 🙃
Problem 3 : High beams never turn on. Even when I flip my switch to go to high beams the check just lights up but not the high beam bulbs. This is the issue I cannot figure out and may need some advice on. I tried it on every setting and no high beam bulbs
