2000 Camry LE 5S-FE engine with 181k miles. I got the car two weeks ago and noticed excessive wear on the inside of the right front tires. I took the car in for an alignment, but the shop said that they couldn't do it because the tie rods were bad. All inner and outer tie rods were loose by my inspection, so I replaced all of them* yesterday, then took the Camry in for an alignment today. I attached the results.
Importantly, the right front camber is at the limit of normal, as is the right rear. Before I knew about camber kits, my Tercel needed one per the alignment shop. A $190 alignment (from a different shop) became a $350 job with an overpriced camber kit ($80 from them vs. $20 on Amazon).
I'm thinking about buying front and rear camber kits (about $20 each on Amazon), then installing them myself, then taking the car back for an alignment, which the shop said that they will re-align at no extra charge. This would be preventive maintenance, as I expect the camber to get worse over time. Thoughts about that?
Although the shop is 4 miles from my house, I want everything as close as possible to normal as possible if I'm going to do a DIY camber kit install. Today, on the way to the shop, the car pulled to the left A LOT, though I had no trouble driving it. Last night, I noticed that both front tires pointed to the left, so I adjusted them to point straight. I got pretty close (.27' and .22' with .10' being upper limits of normal). I didn't see any DIY threads on alignment in Toyotanation (TN), though there are several on YouTube. Anyone know of a TN thread on point?
* I saved $532. The alignment shop's estimate would use O'Reilly's MasterPro EV301, which have a lifetime warranty, and cost me $26 at O'Reilly, $97 for each tie rod on the alignment shop's estimate).
