As we rack up miles, and get fed up with the oil burning, the idea of putting a newer 2.5L seems worth the hassle if the swap is straight forward? The engine has more power, normally less miles and are definitely out there. If someone is lucky enough to find a rear ended 2010+, they would be able to take the engine, ecu, tranny and sell the old stuff with shell to cover some of the expense. If you going to have to do the swap anyway, why swap in the same engine that seems super reliable in all other ways but will have the same piston issue?
Also, are there no aftermarket pistons that can be swapped in to fix the known burning issue? Maybe grab from a Lexus engine or something? I dont know how it all works but 10 years later, I'm surprised the only option that works is replace and wait for same problem to happen again....
