Guys,
I am shopping for the right timing belt, but I am not sure which one to choose, what do you think of Dayco timing belt kit? Is it OEM?
Dayco is one of OEM manufacturers of accessory belts, so i guess that kit would be good enough. have no idea what good is their water pump though, maybe someone else knows.
here is my parts list for quite extensive timing belt & water pump job on 2000 camry solara 2.2L 5s-fe (california specs, auto tranny):
13568-09041 - Timing Belt
90080-31022 - Seal (Crankshaft)
90080-31023 - Seal (Camshaft)
16110-79026 - Water Pump assy, w/o cover +gaskets
90507-17003 - Tensioner Spring
15188-03011 - Gasket (oil pump)
15165-74020 - Seal oil pump o-ring
13503-63011 - idler sub-assy no.2
90916-03090 - thermostat
16325-63011 - water inlet housing no.1 gasket
used original TLLC,
$480 labor + parts $200
it only does not include the tensioner as it was changed the 1st time (with Bosch water pump which started dying after 2 years and roughly 12k miles, complete bullshit). aftermarket Gates timing belt kits are also good (can get them cheap on
www.rockauto.com). however I prefer OEM parts only around engine.
you could pick your own parts from that list and order them online from online toyota dealer (all new OEM) from one of those:
a)
www.1sttoyotaparts.com - Tacoma, WA
b)
www.toyotapartszone.com - Dallas, TX
c)
www.toyotapartsoutlet.com - Charlotte, NC
choose based on your geo location as it impacts the shipping time (via UPS ground) heavily, their prices are comparable.
also if you need OEM parts listing for your model exactly (so you can double check what I gave you above), use:
www.toyodiy.com/parts
give it your car's VIN number for exact listing, then you can either search by part name or number and make sure you have correct OEM part numbers based on their catalog (very accurate).
hope it helps.
