Hey guys I have the LE Plus and wondering what gas do you guys use on your Highlander? I want to make sure I’m using the correct one. I usually select the middle level.
Thanks
Thanks
It's another fuel thread!!!
Whether something helps or not depends upon physics, unless it is a subject that cannot be measured by physics.Just like brakes, fluids, suspension, use whatever you decide to use. Whether or not it helps is up to you and only you.
Correct, it's in the Highlander Owner's Manual - Page 665.I thought I read gas with up to 15% ethanol ok in my HL. ...
That certainly sounds reasonable...ECO light off, DI only. But, I have no knowledge of the algorithm. It could be as simple as "cold" vs "hot" engine, with FI only used when the engine is cold.For instance is anything the turns off the eco light on dashboard safe to say a true indicator of DI over FI? How about >3k rpms?? Or >2k rpms??
Then I suggest you take a class in statistics. Too many unknown variables for anyone but you find the data valuable.I don't find it insignificant at all, since I had a similar experience with a Celica, and let me tell you, mileage always dropped off in that car when I went to 87 octane.
Why would you do that? Difference between 87 octane @ $2.00 and 93 octane @ 2.40 -93 octane costs about 20% more.we hope to do that here
