UPDATE-FIXED: Strut replacement issue: knock/clunk
UPDATE: I have fixed this issue, see my post below
I Spent the day yesterday replacing all four struts on my '07 LE. I went with KYB, the installation went well (so I assumed). I put everything back together exactly as I took it down. Outside of the struts alone, I reused all other parts as everything seemed to be in good order.
Test drive: I seem to have a knock/clunk when going over bumps/pot holes at low speed (<35 and especially <15mph). At highway speeds (65+), I do not hear it at all, even if I hit something. I had a friend ride in the back and confirm that it was coming from the driver's side (left) rear.
Took everything back out and inspected, I noticed that the strut mount has a flange that runs to the flat side of the strut rod that looked a little worn, so decided to go buy a new strut mount (Monroe garbage, only thing available locally). I did notice the Monroe strut mount didn't have that flange the OEM one had, it is just a circle...I didn't know if that mattered. I Put in new strut mount on, same sounds in the same conditions.
I am open to any ideas, I want the clunk to go away.
