I'll probably change my spark plugs with a year or so. Last time I did them I had the iridiums and I did not use a torque wrench. I did not see a torque spec on the plugs themselves, does the torque spec get set via the plugs or what Toyota specifies ?
Last time I did them, I hand tightened them, then probably tightened them another full turn or so and made them tight. I've read that if you overtighten the plugs you can strip the threads since the block is aluminum.
I did not use a breaker bar or anything, just a standard rachet wrench. The threads likely did not get stripped b/c of tightening without a torque wrench did they ? I probably will use a torque wrench in the future, but something I never thought about before and now thinking about the last time I changed them.
