2007 Camry V6: how milles to warm up to reach normal temp?
When i start cold (30 F ) it take at least 5 milles (in town) to reach the
''ALMOST'' 9 O CLOCK mark on the temp gauge or 185 F on my
ULTRAGAUGE connect to the OBDII connector.
At 20F outside temp or less : i plug the block heater (cartridge type in the block (not coolant) )
Then when i start the car the TEMP on Ultragauge is 60F after 2 hours on 110 Volts.
then go to city..........and take the same 5 milles to reach 185F. so same time.
My Question: is it NORMAL that it take at least 5 milles to warm up at 185F.
is my thermostat OK because it is a big (long) job to replace myself and it is cold outside .
Q.: 2 : When i stop the car about 25 minutes (20F outside temp)) the temp is downdown below the first white mark on car gauge.......
normal or not ?: ( if not :maybe the radiator pressure cap?)
never had a japanese car.......my caddy was at normal temp before 5 milles
tyvm to replys:smile:
