I want to add at least 10 Horsepower to my 2.2 engine can I buy a cam that can do this or more?
I used to use them all the time, until I started running oil samples to Blackstone and saw the increase in silicon contamination.And yes, high air flow filters don't really do much. As I have them on all of our cars since 2001 or so.
Instead of servicing your muffler bearings replace them with turbo mufflers.
Good for you. Time and money well spent.This past weekend I replaced all four struts with KYB strut plus assemblies (about $480 minus $100 rebate, hopefully), installed 4 new Moog problem solver end links (about $120) and replaced OEM RSB (17mm) with a Whiteline BTR39 20mm rear sway bar ($180). The difference is pretty dramatic. It is clear that crank torque and HP won't change. But by preventing the car from sloshing around, probably more torque and HP can be passed down to wheels? I think it is possible because my butt dyno improved a lot. (If someone can explain my experience in scientific terms, it will be really helpful.)
As to OP and possibly others in the future, considering updating/improving the suspension parts is another route when you want to improve acceleration. The end result is from the wheels, so you don't have to always focus on engine. Feeling is believing!
